reverse beeper stuck on all the time
ok so last night me and a couple of friends were out ripping and messing around when my one buddy wanted to drag me so we did and i blew my belt doing 80 km/h. so he towed me back to his place and left my sled for the night this morning i go put a new belt on after picking the old belt and all the strands out of the secondary. so after i put the new belt on i decided to take it for a rip and hit the reverse button and backed up away from his sled when i hit the button again to go forward the reverse beeper stayed on with the reverse on the cluster or the display and never went away it kicks in and out of reverse and is still can go forward and but the stupid beep wont go away and it shows on my display flashing the R for the reverse has anyone had this problem before i have a 2008 m-1000 snowpro with a slp full system air intake and boondocker control box any help would be great thank you
Yup! Same thing happend to me after a blown belt. The belt took out the alarm switch so I replaced it with a new one. It worked for a few days and the reverse alarm started sounding while going forward. I unpluged it, got another switch and the same thing. SO! I buy a pre owned reverse actuator with the alarm switch included and yup, you guessed it, still have the alarm going forward. So my switch is now disconected again. I don't know what the fix is other than maybe the alarm itself is at fault????
[From the service manual...
The CCU performs two important functions on the
snowmobile. Its main function is to distribute regulated
DC power to the chassis electrical systems. Its
other function is to control the forward/reverse shifting
of the ACT drive to ensure safe operation.
The CCU has two DC outputs used for lighting circuits.
Both outputs have a circuit breaker (self resetting
devices) which protects components from overcurrent
and short circuit situations. If a system stops
working, it is likely a short has occurred and the system
has shut itself off much like a fuse will blow if a
circuit is shorted to ground. However, unlike a fuse if
the short is resolved, the CCU will reset the output and
the system will return to normal operation.
The first output, labeled the High Power DC Output,
supplies power for the headlights and handwarmers.
This output is on only while the engine is running.
This output is turned off during shifting to allow maximum
power transfer to the ACT drive.
The second output, labeled the Low Power DC Output,
supplies power to the gauge, speed sensor, taillight,
accessory plugs, and APV servomotor via the Engine
Control Unit. This output is on only while the engine is
running. It is not turned off during shifting.
CCU Diagnostic Codes
Code Trouble Cause
CCU 32 High power DC output
over current.
Headlight and Hand Warmer
(Red/Black) circuit current
greater than 20 Amps.
CCU 33 High power DC output
shorted.
(Red/Black) circuit shorted to
ground.
CCU 34 Low power DC output
over current.
Gauge, Taillight, and APV
Servo Power (Red/Blue)
circuit current greater than
20 Amps.
CCU 35 Low power DC output
shorted.
circuit shorted to ground.
CCU 37 System over voltage. Spike in battery voltage -
excessive gear case shifting.
CCU 38 Gear shift actuator
failure.
Wires to reverse actuator
damaged or shorted to
ground.
CCU 42 Tachometer input failure
(engine running - no
tachometer signal
present).
Tachometer signal wire
shorted to ground.
CCU 43 Gear position switch
failure.
damaged or unplugged -
reverse actuator not
working correctly.
CCU 44 CCU over temperature. Internal CCU temperature
over 105° C (221° F).
Just a guess, but isn't there a loom of wires that run behind the secondary clutch that sit on the bulkhead in front of the fuel tank? Maybe a blown belt smacked them wires and pinched them causing a bad connection or a ground fault? Just trying add an idea of something to look at??
