A
I'll keep a long story short, but recently bought a vehicle that had the trans rebuilt at this place shortly before buying it. Confirmed with the owner Jeremy at AAA since the PO didn't have the receipt.
After putting a few thousand miles on the rig, the lack of workmanship is evident.
Loose trans to T case adapter bolts.
RTV sealant smeared around the adapter to T case connection.
Trans mount missing the nuts that hold it to the x member. (1 nut was there but only threaded about halfway up, other one missing)
Tq converter inspection cover missing (not a big deal)
T case fill plug chewed up and stuck in t case and trans pan drain bolt chewed up. (Someone needs their vice grips shoved up their ___ sideways!) Maybe done before the shop got the vehicle, but shAtty if they sent it back out like that. Can't change the T case fluid or even see what's in it because it'll have to come out of the vehicle likely to get the fill plug out.
And it has the typical hard 1-2 upshift that is prevalent in alot of 4L60s. Some rebuild...
Either way, not embellishing here, but I wouldn't take a bicycle there for repair after seeing this mess.
