• I've received emails and PM's asking me about "Group Buys" and promotions.
    A Group Buy here on SnoWestOnline.com would be a situation where a normal member (non vendor or mfg) personally collects orders from other members. That member then uses those orders to negotiate a better price with the Vendor/Mfg for HIS/HER "Group" of buyers.
    Here is an example of a viable "Group Buy"
    http://www.snowestonline.com/forum/showthread.php?t=269222
    A promotion that has the words "Group Buy" in the title is still a promotion, and from the rules that were handed down to me by Harris Publications is that non-advertisers cannot run promotions or open sales programs on the forums outside of the swapmeet.
    If a members wants to become a group buy manager, maintain a thread and collect the funds and negotiate a group buy... as a member, you are welcome to do that as long as you are not attached to the business of the vendor or Mfg.
    If you are a vendor/MFG and you want to offer an EXCLUSIVE "SnoWestOnline ONLY" promotion that is exclusive to snowest readers, please contact me and you'll be able to put it up in the Polaris forums.
    Also, before any vendors/mfgs get all "riled up" over this know that the moderators are strictly volunteers and do not receive a dime from any advertising $$ spent on this site.
    As ALWAYS, since DAY ONE of me becoming a moderator, I have pioneered, supported and encouraged vendors and mfgs in getting the word out to our readers with "New Product Announcements.
    Have a great season.
    From this point on, all vendors/mfg's promoting Pre-Season tiered sales programs, in the Polaris Forums, that are not paid advertisers will be appropriately moved to the swapmeet section of the forums.
    MH
Pro RMK not Pulling RPMs
Oct 23, 2015
I'm running a new to me 13 pro RMK. Been having issues with it reaching peak RPM, since I've owned it, it's never pulled tach higher than 8000. Today it at 8000 ft with 10-60 weights it would only pull 7450-7500 rpm. I noticed that there was a check engine light on stating 173-3 or high voltage exhaust temp sensor. Could this be keeping me from. Holding tach where I am supposed to be? I'm pretty lost, I haven't checked my secondary spring or anything inside the secondary yet, but everything in the primary looks great. I hate missing out on the peak horsepower because it makes riding super difficult. Any help is appreciated.
cascadesnowjunky
1,326
630
Kennewick WA
Yes normally it wont rev past 6500 - 6800. I just replaced one on my 17 axys last year and I had to replace a couple on my 11 pro. When mine went out last year it pulled rpm a couple times just randomly on the way back to the truck but when they go they basically are stuck in limp mode.
cascadesnowjunky
1,326
630
Kennewick WA
If you have a check engine light that is on and says 173-3 you may as well just go buy a new pipe temp sensor because there is no other way around it. They are not cheap but that is the issue.
cascadesnowjunky
1,326
630
Kennewick WA
The reason is that sensor has a huge roll in the fueling, they did it to keep from burning it down. It needs that perameter to adjust the fuel supply to the engine.
Feb 21, 2009
800
88
Does the light stay on? mine would come on going down hill but go off once i pinned it wide open. Now if you getting to 7500 its not in limp mode belt deflection is important. Mine rarly goes much over 8k but when hit powerband it will hold solid. Its sounds like you need to buy a exhaust sensor anyway. have you cleaned the powervalves, if not opening all the way is a issue.
Have cleaned powervalves, and light does stay on. I'm sure there is more to it than just the sensor, but it can't be helping matters.I only occasionally got 7500, most of the time it was much closer to 6800-7200. I rode it the entire day and the light was on the entire time.
Oct 23, 2015
Also belt deflection is perfect
hamlin
464
188
Look on eBay if you want used, but like you said, what if the used one only lasts a month
Oct 23, 2015
Pulled my Reed cages out and the petals are starting to chip and flake. Is it possible to get new petals? And if so which brand should I get? I would like to about getting a fuel controller, but will if needed. What is best vs most inexpensive option?
Oct 23, 2015
SRXSRULE
2,512
1,569
Thanks is for the info I'll give it a test!! That makes things easier for sure. And the SPI one will probably be what I get. Any suggestions on new reeds?
I only use Polaris reeds in these engines. V-force reeds tend to cause idle problems in these years of Pros. How bad are they? some small chips are normal. Are the reed petals still covering all of the opening in the reed block? If they are, they still have some life left in them. You can also take them apart and flip the petals over if they are not sealing tight up against the block.
Oct 23, 2015
They are only mildly chipping, nothing major, just don't want them to completely break and destroy the motor. I'll attach pics. I'm also getting 5.045vdc as the input voltage to my TPS when I try and reset it, with two different fluke 88 meters. Leading me to believe I may have voltage regulator issues.
IMG_20191213_195218.jpg IMG_20191213_195223.jpg IMG_20191213_195227.jpg IMG_20191213_195235.jpg IMG_20191213_195240.jpg IMG_20191213_195243.jpg
