Polaris driveshaft and track failure tally
V
volcano buster
1,613
Stayton Oregon
I'm seeing a disconnect.
The '13 drive shaft had the end come out of the tube thus the need for the clamp. The pictures of the '21 shaft failures appear that the clutch end simply breaks off at the end of the tube. A clamp won't solve this.
810
Elko, NV.
I towed a 155" Khaos off the mountain a few weeks ago with a broken driveshaft. He mentioned it had been ratcheting like crazy prior to it snapping the end off. I'm guessing this 3.5" pitch and no antiratchets on clips is the culprit. I believe it's the same pitch as Ski-Doo but they have clipped antiratchets.
Nov 20, 2020
40
30
Do I remember hearing that the 2.75/ QD2 got a new driveshaft as part of the package? I'm not seeing any 2.6/ QD1 failures on this list... Different driveshaft maybe?
kylant
1,664
393
CA
what do yo mean by "clipped antiratchets"?
810
Elko, NV.
Most manufacturer's have anti-ratchets on the drivers that drive off of metal clips on the track widows. What people have been doing is putting a big anti-ratchet driver in the mid-section of the polaris track driving off of non-clipped rubber and polyester cords. In a few hundred miles these tracks are toast.
BrapBirk
25
20
My center driver has been slowly moving to the point where it now rubs the track window.
2021 pro rmk 850 155 series 8 qd2 500miles 30hrs
7,908
6,658
2x2 piece of wood and dead blow hammer you can center it up again.
Likely you should make your drivers on each side of the center driver tight to the inner or outer limits of the track nubs when the track is centered in the tunnel.
This will keep it from walking.
RanOutofTalent
400
69
Western Montana
21 khaos qd2 with the 2.75
My track has been tightened 5 times at 600 miles and finally stopped ratcheting.
I am quite disappointed as it has lost 2-3 paddles or split some.
I don’t get why this thing seems to be falling apart
284
Alaska
5 times! Those are rookie numbers!
I'm a little over 600 miles. I check and tighten it before every ride, and by the end (50-70 miles) its ratcheting again.
Dec 5, 2010
450
404
Sḵwxwú7mesh, BC
My track doesn’t really ratchet. I keep it adjusted to spec. But I’ve noticed the wheels are running off the rubber under the rods. Even causing 2 holes on the wheel tracks. Hoping for warranty on this one
Check your tracks and see if they are wearing out. Start a warranty claim if so !
