Does anyone know if you can still get these somewhere? I bought 2 last year and they were great with the AC magnetic tether.
I sent a text and email to the guy that was selling them last year, but haven't heard anything.
What he said. I ordered the tether from ZRP but didn’t want to drill another hole in my plastics. I saw TKI has a nice bracket that mounts under the handlebars where the base of the tether mounts.Bought the whole setup from TKI - harness, tether and bracket. Looks well made.
For you guys that like to build you own harnesses I found a supplier for the AC tether:
Connector for tether: Newark Molex Connector
Terminals for tether: Newark Molex Terminals
The seals are an issue from Newark they show backorder from UK Newart Seals Looks like you can get them from Mouser Mouser Seals. I had some red metripack seals in my stuff and cut them down shorter and used them.
Deutsch connectors: you re-use the connector used for a dust plug. You will pull the green wedge out before inserting the pins.
Terminals if you don't have the deutsch tool: Newark Deutsch Stamped Pins
Terminals if you have the deutsch tool: Newark Deutsch Solid DT Pins
Hooked mine up today and it worked great, way better than the clip type tether I had!
You don’t happen to have more info on how you put this together? I have everything I need for this but the harness/wire to go from the Arctic Cat Magnetik to Axys 800.For you guys that like to build you own harnesses I found a supplier for the AC tether:
