P1324, P0264 injector wires breaking..
summ8rmk
Most handsome
11,827
5,305
yakima, wa.
Anyone get this lovely code?
Knock control system activated.
Just enough power to get sled up the ramp.
Sounds like a 4stroke, power of a one cylinder 200cc engine.
Sent it
ak
2,776
722
I had that code once, it limited my top end but I shut it off, restarted and ran fine . Shortly after I did have to replace my pipe sensor but don’t know if it was related.
summ8rmk
Most handsome
11,827
5,305
yakima, wa.
I am definitely having fueling issues.
Mag side is dry.
Checked ohms at the injectors pigtail.
#1 100ohms, #2 11.9ohms...
Sent it
summ8rmk
Most handsome
11,827
5,305
yakima, wa.
Simple problem. Broken wire.
Now if i can figure out how to disassemble the connector i can repair it.?
summ8rmk
Most handsome
11,827
5,305
yakima, wa.
Soldered back together.
Both injectors are 11.9 ohms. After fixing harness, they both ohm 11.9 at the end of the harness also.
If u have any issues like this, just unplug the harness behind the muffler and check ohms. Yellow is MAG side and green is PTO.
Sent it
Chewy22
1,834
1,049
Montana
Sent it
how was it getting the pin out of the plug?
Wapow
486
339
Beauty solder job! I need to get one of those wire holder thingies.
