Oil pump...
skud_rider
New member
Jun 5, 2008
25
Hey guys Im installing a new motor and just wondering if there is a way to bleed the oil pump on the 07' 800r? And how do you remove the water pump impeller?
Thanks
AKtoad
391
157
Anch, AK
Look at the impeller it has two small holes 180 degrees from each other, use some needle nose to hold the impeller in place while you loosen the nut. Every motor I rebuild I replace it, to me its just cheap insurance.
