No idle after top end rebuild?
Scott
Scott Stiegler
69,618
11,737
W Mont
10psi of cranking compression and it still runs?
Just for fun, if you hold the throttle safety switch in (the hinged part at the throttle block), will it still idle?
While it's idling...
Do you have headlights?
Does the dash gauge still work?
Have you checked the power at the DC and AC wire harness down by the voltage regulator on the clutch cover?
R
Nov 21, 2018
8
2
1
Hey there, late to the party but i just rebuilt my 15 pro and am having same issues, wondering if you were ever able to figure yours out? when i was trying to get it running i did move the tps sensor and got it to idle fine but has no power under load on flat ground and cuts out. adjusted my TPS to factory specs and now back to not idle and backfire. looking for help here its making me crazy. Thanks
Vincenthdfan
870
199
Olympia, Washington
Gotta make sure you hold throttle body butterflies wide open too when youre doing compression test so that the engine can get some air to it as well...easily forgotten step if your not well versed in doing them.
diamonddave
Chilly’s Mentor
5,569
3,866
Wokeville, WA.
Exactly. Sounds like the OP is long gone and never reported back but there’s no way that sled is going to start on 10lbs of compression
