• I've received emails and PM's asking me about "Group Buys" and promotions.
    A Group Buy here on SnoWestOnline.com would be a situation where a normal member (non vendor or mfg) personally collects orders from other members. That member then uses those orders to negotiate a better price with the Vendor/Mfg for HIS/HER "Group" of buyers.
    Here is an example of a viable "Group Buy"
    http://www.snowestonline.com/forum/showthread.php?t=269222
    A promotion that has the words "Group Buy" in the title is still a promotion, and from the rules that were handed down to me by Harris Publications is that non-advertisers cannot run promotions or open sales programs on the forums outside of the swapmeet.
    If a members wants to become a group buy manager, maintain a thread and collect the funds and negotiate a group buy... as a member, you are welcome to do that as long as you are not attached to the business of the vendor or Mfg.
    If you are a vendor/MFG and you want to offer an EXCLUSIVE "SnoWestOnline ONLY" promotion that is exclusive to snowest readers, please contact me and you'll be able to put it up in the Polaris forums.
    Also, before any vendors/mfgs get all "riled up" over this know that the moderators are strictly volunteers and do not receive a dime from any advertising $$ spent on this site.
    As ALWAYS, since DAY ONE of me becoming a moderator, I have pioneered, supported and encouraged vendors and mfgs in getting the word out to our readers with "New Product Announcements.
    Have a great season.
    From this point on, all vendors/mfg's promoting Pre-Season tiered sales programs, in the Polaris Forums, that are not paid advertisers will be appropriately moved to the swapmeet section of the forums.
    MH
New Gates R belt.
kanedog
Undefeated mountain clutching champ of the world.
2,128
1,811
What is the angle of the belt? I understand if it is a Trs protected secret sauce!
702
Elko, NV.
26 degree results in a a much quicker break in and much less stress on the top-cog portion of the belt especially during break in. I have been running a Gates R belt as of late and do not have any complaints, belt grip is good, no detectable slip, consistent RPM's and the best part of all is my sheaves aren't brown with gooey compounds being released from a hot belt after a smokin' fast 7 mile bump run down to the truck on a 60 degree afternoon.
BeartoothBaron
699
621
93
Roberts, MT
So does the shorter break-in have anything to do with the compound? I've been very happy with the C12 belts – except for the break-in part, and that's on older sleds with a matching side angle. To properly follow the recommended procedure takes up most of a morning of riding. I've got lucky now and then with enough snow to break one in near where I live, but then I've found having only one correct, broke-in belt means something bad happens to it (my fault, not the belt). So it's hard to predict when you'll need to break one in, and even after a couple full days of riding, the belt still doesn't look fully bedded in.
I thought about trying the 47R belt a couple months ago, but it's much harder to find (talking about the standard 28º), and I figured there'd be little benefit over the C12. But if I get caught out again (though I think I've learned my lesson), I might try the 47R. That said, I had a similar experience to AdrenalineAddict on my last ride: was warm all day, hard to keep the sled cool at times, then finished off the day with a blast back to the truck (fortunately, the snow was more slushy lower down). Other than a small ring at the base of the primary, the sheaves are bright and clean. I also follow something TRS recommended a while back: I grind the side of the top cogs flat (perpandicular to the top of the belt). Seems to result in less build-up during break-in, and probably keeps the belt cooler.
702
Elko, NV.
I went for a burn this morning, approximately 200 miles on the R belt and swapped belts about midway through the day just for comparison sake, I was seeing approximately 50 more RPM's with the R belt over the 216 in long belt heating pulls, the ambient air temp was probably 50 degrees. I'm guessing in the cold dead of winter we'll see nearly identical running RPM's, but I feel the R belt will shine and fade less when clutch temps climb. At this point in time I for one am feeling real good about this product, no more sheave cleaning when I get home makes me a happy sledder. Im curious what TRS's experience with the belt has been, he probably has more hours on these belts than most.
TRS
Life Member
3,328
4,093
Cody, WY
The 47R with the 26* is running more rpm than the standard 47R.
I believe it relates to the standard belt narrowing during breakin. That allows for a little wider belt to sheave measurement which loads the engine.
702
Elko, NV.
I put another 55 miles on the R belt again this morning, nothing but smiles at this point. It performed flawlessly, 8350 on the 7,800' trail ride, mid mountain 8,100, and 7950 to 8000 all the way to 11,000', no slip, solid backshift. If it is as durable as advertised it could be that Gates actually built a better mousetrap.
