1
Everything is new or been redone and never seen snow. This is a full of custom build with absolutely no expense spared. Fully powdercoated,polished with every nut and bolt either ti or alum no steel at all. Testing water to see if anyone is interested in parts.
KK bulkhead that is lightened and done in croma base paint with clear
New Tison mountain 162 tunel with full polish and ghost flames etched in rear,and powdercoated edge extrusions
New CR powdercoated and polished gas rack
New Tison powdercoated alum bumper
New CR huge custom full lenght u-cooler
New KK stock tunnel inside edge coolers
New CR cro mo steering hoop powdercoated
New CR racing front tunnel kick ups powdercoate
New CR racing alum suspension drop brackets powdercaoted
RMI drive and spare different ratio rmi drive all polished
Rmi lightweight cro mo shaft,rotor and pads
RMI billet cnc caliper all polished
New Avid drivers
All new belly pans
New skid plates
New clear tank
New flowrites in clutch,bellypans and exhaust shock wells.
New cat skis and hoops with powdercaoted saddles
Fabcraft billet spindles
New fly 6" risers
New fly aero taper bars
New billet resevoir and brake lever
New billet gas cap
New billet pull handle
New billet throttle block
New rsi grips
New rsi mountain grab bar
New boss seat
Polycarbonate hood
New light cover
New front hood bumper
New front belly pan bumper
New motor mounts
New motor torgue stops custom made
New black magic motor torque rod
New 174x16 extreme
New polished 174 ice age rails
New holz rear suspension with coil overs all powdercoated
New billet and polished billet wheels on whole skid
New antistab
New billet inside 2 wheel axle kit
New fabcraft cro mo control arms
Fox float
New fox float cover
New NX express nitrous with all billet nozzles and manifolds,bottle warmer,seprate battery,etc,etc. The best of the best nitrous kit
New Billet nitrous manifolds
New psi 1400 never ran,billet rad crank,alum lightweight waterpump shaft,dial a domes,boyseen rad valves,all gone through by brent linderman
New boyseen billet rad valves
New psi billet manifolds
New psi 46mm d-bore carbs
New kickass filters
Racepack avenger 3 with download and all software and all options possible from reacepack
All bolts and nuts either alum or billet
Where strenght was not critical all fasteners were even holowed out for weight. Some of the bolts in the rear skid and suspension are $60 a bolt.
ETC,ETC as probably misses some. As mentioned the best of the best,lightest of the lightest and strongest of sronges material and parts uses. Not a dime spared and every piece was coated or polished and new or rebult. It weighs a tad over 400lbs full of fuel ready to ride. It has been on my hoist for 5 yrs now ready to drop motor in and ride. Again never started,rode or seen snow. When built we are looking at around a $40 grand Canadian $ build. Let me know if any interest in any of the parts and send me a reasonable price and we will go from there.
New Avid drivers
All new belly pans
New skid plates
New clear tank
New fly 6" risers
New billet gas cap
New rsi grips
New boss seat
Polycarbonate hood
New light cover
New motor mounts
New 174x16 extreme
New antistab
Fox float
New fox float cover
New kickass filters
