W
WSLN 6
New member
Need some insight! Will give a little history of facts then the issue.....
Starts 2nd pull
2871 turbo with xic controller. Cleaned/flowed injectors.
Egt's both climb evenly, fuel in Y pipe looks even.
Aftermarket Fuel regulator set to 39, holds there at idle.
Wideband sensor is 14.7 at idle then goes off the chart lean as it dies.
Top end rebuilt, very meticulous with it including all wiring.
TPS set and calibrated in spec, new Rage cages with carbon reeds.
Idles at 3400 as soon as it fires up.
Unrelated (maybe?) Pro armor tether ohms correct, but does nothing when pulled (parallel with kill switch, measures right but if pulled kill switch no longer works either) It has been dry for 2 years so moisture is a no.
Any and all help is appreciated!! Stuck.....
Starts 2nd pull
