I bought a 2018 800 axyis the first thing I did was take it to Shawn to install his turbo kit. all I have is good to say about Shawn and his kit it just flat works wonderful. Shawn worked with me on every issue I called him on until it was resolved. thanks Shawn you have made it a truly enjoyable experience. I am not kidding it will work flawless at 8 lbs or 15 lbs it JUST WORKS.
Next, the other thing you have to have for it is a KMOD suspension. without the KMOD the turbo is worthless. because the front end is always in the air and out of control. you talk about tech support there is no better than KMOD. Kevin will take the time to make sure you have everything perfect for you and your riding style. From changing spring rate, air pressure in shocks to correct setting in the chassis Kevin is the Man for all your suspension needs.
