motor exchange02/03 800 RMK into 98-700 RMK?
:beer;Will a 02-03 800 RMK motor fit into a 98' RMK chassis? have any other suggestions? I think the pipe would become an issue::beer;
POS Pol
172
6
45
Arthur NE
The motor will fit easy. One of the coolant lines is little different and the coil system is quit a bit different. Just use the coil off you 700 and remount it on your 800. To get the pipe right just order a pipe for a big bore 700 and the should take care of it.
119
Salt Lake City
swap
I ran a 02 in a 99 700 chassis. The 99 bulkhead is the same as the 98 but has different plastic. I ran the 2000 SLP pipe with a Y pipe off a 01 XC. The 01 XC was a VES motor mounted straight up and down instead of tipped forward. No mods needed to the pipe. SLP said the 800 non VES pipe had the same volumn as the VES 800 and it worked great on mine. I still have the Y pipe if you need it.
rmkboxer
323
46
Bonney lake WA
use the motor plate out of the 98 and get the intake boots from a 00-01 800 rmk and the pipe is up to you. if you need intake boots pm me I have a couple of sets
