Melting heat guard
2014xm
I am running the j&t can and the gaurd over the wires and lines has been melted as shown in picture. Anyone have a solution or same problem was running full throttle all day last weekend since it was super deep. the stock heat shield that was on stock can is too long to go over this can. Any help
I'd make my own heat shield for it personally... possibly a little bit of new/extra venting too.
In the short term if you need to get out riding, I'd just swap the stock can back on for the time being.
You definitely need the heat shield. That's a bummer it doesn't fit. It fit back no problem with my cans. It surprised me they did have instructions to put back on with the cans. The closeness of the neck and that flimsy plastic guard is a recipe for disaster.
Yeah it sucks. The can bends right where it hooks on so it won't fit unless I really make it and cut it up. Probably put stock can back on until I find a turbo that works.
If you can modify so that it will fit, it probably will do the job. Or if you even foil tape that plastic shield you'd probably be OK. It's amazing what a thin layer of aluminum can do.
After a lengthy battle with heat management on my turbo Yamaha, I can attest the effectiveness of heat shielding tape.
Not plain foil tape, but proper stuff used for racing, typically from an auto parts store. You can get it in rolls and sheets, but it ain't cheap. The narrow tape is good for covering wire looms.
Also, as mentioned, header wrap, placed directly on the section of pipe will help too.
That's disappointing, I was going to go with a J&T until I read this. Now I think I am going with a Precision Design and Manufacturing can. Here is a link of the install and sound clip
https://m.youtube.com/watch?v=VfYY0mno4WE
I have Diamond S and I know they are more expensive but they are top notch quality and don't seem much louder than a stock can. The heat shield fits on the throat just like it does on the stock muffler.
