Ran into a problem
So I ran into a little problem...
Since I machined .060" off of each side I need to remove one .060" shim from behind the clutch to maintain the alignment with the primary clutch. The problem is the DD shaft is too long to allow for this and now when you tighten the bolt holding the clutch onto the splined DD shaft it does not "clamp" the clutch to the shaft. The clutch actually floats back and forth like and old style clutch with a keyway. I have read on here that you don't want to do this with the DD setup but don't know if anyone has tried it. My only other option would be to remove the shaft from the DD and shorten it, but I really didn't want to get into that.
As anyone run this floating style setup on the DD sleds? Any of you guys that have done this before run into this problem?
