*** Attention 2022, 2023 and 2024 Boost, 9R and 850 Owners ***2023 boost with bikeman tune. Updated the 7s display and it no longer shows the different tune options. Are the tunes gone? Anyone else run into this?
I've already installed the 23 version and it didn't bring the tunes back. Do I need to have BMP tunes installed again?*** Attention 2022, 2023 and 2024 Boost, 9R and 850 Owners ***
If you have an updated 24 and lose RPM on 7S gauge after installing BMP flash you must update the 7S to this file. 2024 7S UPDATE
If you have an updated 22 or 23 and lose RPM on 7S gauge after installing BMP flash you must update the 7S to this file. 2022 and 2023 7S UPDATE
On a 23 you need to run the version they recommend or you will loose the option to change the 3 stages and possibly the RPM reading.
If you have an updated 24 and lose RPM on 7S gauge after installing BMP flash you must update the 7S to this file. 2024 7S UPDATE SNS7BA.N22248A.swu This is the Dec. 20, 2022 version of 7SDD software. It has a LOT of bugs, glitches and freezes.
In the above post I have added the actual versions of 7SDD software, associated with those links.If you have an updated 22 or 23 and lose RPM on 7S gauge after installing BMP flash you must update the 7S to this file. 2022 and 2023 7S UPDATE SNS7BA.N32306B.swu This is the March 23, 2023 version of 7SDD software which supports MY24 features. VERY reliable.
