Limit strap question
K
klarkkentster
307
77
Bremerton, WA
Just bought a 2022 Edge and getting ready to install the adjustable strap. Suggestions on which hole I need/should start with? Does it make a big difference going from tight to loose?
MTsled3
719
682
93
Belgrade, Montana
Shorter hole is equal to stock strap at holes 3(when adj is set long) to 5(adj set short), longer hole is equal to stock strap at 2 to 4. You have to make sure the stock strap is in the right hole too, 3rd hole if you run the adj in the shorter hole, or 2nd hole if you run the adj strap in the longer hole. Just set this up on my fiancee's sled yesterday.
K
klarkkentster
307
77
Bremerton, WA
Did you go 3 and 5 on the two options - or 2 and 4?
