lightweight 503
J&L Snowhawk
1,269
288
Aberdeen, SD
stores.ebay.com
Not sure I under stand what you're saying but stock rails are junk! They were too short. This skid has nice approach angle. I have evol shock so you can really get a plush ride with excellent bottom out resistance. There just isn't a easy way to strip more weight off of these things without sacrifice durability.
J&L Snowhawk
1,269
288
Aberdeen, SD
stores.ebay.com
I do think approach angle is better now. As far as weight not sure where to go next. The body work is heavy but not sure how to keep strong and lose weight. I think some modified frame plates can save few pounds
J&L Snowhawk
1,269
288
Aberdeen, SD
stores.ebay.com
progress
so today i am showing the installation of UFO for round slide carbs to drasticlly improve throttle responce.
second is the install of some cyclops led bulbs into stock headlight housing
very easy mod. use a dremel to cut out back of headlight just a bit and install.
J&L Snowhawk
1,269
288
Aberdeen, SD
stores.ebay.com
gauge
got the 503 equiped with a good ol trail tech vapor. want to see what kind of track speeds this bad boy can make. has a cylinder head temp sensor also. cant wait to do some testing.
J&L Snowhawk
1,269
288
Aberdeen, SD
stores.ebay.com
Different
It's hard to compare the 2. The bikes are easier to ride for most and easier in slow technical areas. The hawk is more drifting style.
I guess after riding a yz300 smoker I would say that's it's similar to my hawk style of attacking the terrain. Don't be a quitter or ***** and get after it and a hawk will be the funnest thing out
N
Jan 3, 2008
734
311
Northern Utah
When you weighed it how much fuel was in it? Im running a 700 rmk engine in a fanner frame with a 151 holz skid and 1 gallon of gas im at 440. Which after looking at sheetmetal fabs 800 sno thingy We weigh pretty close to the same.
