Having an issue with the DESS key on my 2017 summit. I installed LED headlights (they're rad) last winter and had no issues. Recently installed the OEM 12v glovebox plug(Has a blue LED ring around it), and that plus the LED headlights combined are causing EMI interference with the DESS key. I can run one or the other with no problems, however once both are powered the DESS says CHECK KEY until I wiggle the handlebars OR the LEDs warm up. I've pinned it down to EMI interference from both.
I'm planning to line the outside of the glovebox with foil tape to try and trap the 12v frequency and if that doesnt work I'll try to tape the exterior of the headlight housing also.
Anyone come across this problem before?
