keep us posted, I may have to try the raised cylinder out once i get my pipe. If its not the curve isn't narrower id imagine its going to be a good setup!
Nice... thats what I am getting out of the 450 with a lot of work!Super cheap trick you can do at home with a dremmel. If you modify the ign pickup (make the bolt holes slotted) and move it all the way to the right, you pick up 3 in the midrange and 1 peak. At your own risk of course. I’m running c111 straight.
looked at a programable ignition but they sure are pricey.
we’re at 45tq now vs ~30 stock.
So what was the peak hp and tq on your 450 and with all the new tech could we figure out how to overlay the two graphs? It would be cool to see the curve difference.Nice... thats what I am getting out of the 450 with a lot of work!
Sent from my SM-F900U using Tapatalk
40 lectron Will get you 2 more if you haven’t ordered the 38 yet.
Did they tell you if they raised the ex port timing? Just curious because that seems to be what the 300s need most and there is a huge misconception that the 300 need to have low end grunt for snow biking. Grunt does nothing without some peak power to go with it.Hello,
Since I just got my 300 cylinder back I figured I'd post some pics and get your guys thoughts.
TMR "snowbike porting"
Head set up for 50/50 110
.5mm base gasket
Will be running a 38 lectron
Getting excited with this build!
Did they tell you if they raised the ex port timing? Just curious because that seems to be what the 300s need most and there is a huge misconception that the 300 need to have low end grunt for snow biking. Grunt does nothing without some peak power to go with it. If they won't tell you the timing measure down to the top of the port from the top of the cylinder. What year is it?
