G
You changed the rails at the same time and those rails have a steeper approach angle. Nothing is going to be pushed down further.
Axys, the bench to cross shaft on the front toque arm opened up 3/8” from the stock rail on mine. That was with the stock shock and limiter strap. I had both on the bench without wheels and hyfax.TRS did you install this on a pro rmk. Not a axys chassis?
I got iceage 163 khaos rails and raptor conversion kit. I measured the front mounting bolt with the factory rails, 11.5 inches from ground. I installed khaos rails with stock limiter strap and shock. It still measures 11.5 inches.. I installed the raptor shock extender and started on the limiter strap only to find the raptor strap is shorter than my stock pro rmk strap. From what i can tell on a pro rmk install khaos rails and the mount the skid in the lower assault hole and save $100 bucks on the raptor scam
Finally took it out for two days of riding........ WOW! If you are looking for more playfulness...... Do it. The feeling on the skis is lighter and able to change direction better through running board inputs.
The sled defiinitely wheelies more and front end feels a lot lighter on climbs--- so if you are a chute slayer, this might not be the best option. I'm not a climber/ highmarker. My riding style has been described by others as "****-holing", I like finding drainages and tree riddled routes to ridgelines where I''m spending as much time traversing horizontally as I am straight up.
The other interesting thing I found with the wheelieing while climbing--- it's NOT a trenching wheelie, leading to a stuck. Now, I left some massive looking "turbo trenches" (normally aspirated), but did NOT get stuck.
I am sold on the geometry.
Snowman. How tight do you have your fts adjusted to. What year of machine. I have a 15 pro rmk 155 and I installed iceage 163 khaos rails raptor shock conversion. I have the fts almost as tight as it will go. The rts is loose and this sled still rides like a tank in the front end.
A pro ride chassis sled will never lose the feel of 40# of concrete attached to the front bumper.........
Amen brothaA pro ride chassis sled will never lose the feel of 40# of concrete attached to the front bumper.........
Nice - You ran the IceAge rails on a PRO with the Raptor kit? Normal bolt position form the front skid mount? I have Khaos rails coming for my AXYS - may want to do the same on my 13' ProFinally took it out for two days of riding........ WOW! If you are looking for more playfulness...... Do it. The feeling on the skis is lighter and able to change direction better through running board inputs.
I wonder with Ice Age rails, longer FTS and longer limit strap plus bolting the front suspension in the lower hole if that will help lighted the front end.A pro ride chassis sled will never lose the feel of 40# of concrete attached to the front bumper.........
Anyone running the front arm in the lower hole? Worthwhile difference?
Sent from my SM-G973W using Tapatalk
Everyone who has done the ice age khaos conversation"rails, shocks and limiter strap" on a 163 happy with the improvements. Thinking about doing there hole kit. Thanks
Thanks for the info. Guess I know what's nxt in the shopping cart then
