Jackshaft changeable
K
Jan 14, 2020
6
I have 2005 Polaris RMK 900 with track pitch 2.52. I am wondering if there is a Jackshaft that we can change to so we can achieve for a track pitch of 2.86. Or how can achieve to go from 2.52 pitch to a 2.86
o2bncamo
189
50
wisconsin
All you need is new drivers from Avid. https://avid-products.com/ You will need to press off old drivers and install new 2.86" pitch drivers.
Dealer can do this or anyone with a press.
The jackshaft is the shaft with the secondary clutch on it. Don't need to do anything with that. The driveshaft has the drivers that drive your track,
that you will need to remove and press on new drivers.
https://shop.avid-products.com/eshopprod_cat_9010-109899_product_1726158.__Polarishydro_pitch.htm This is the driver you need.
mountainhorse
18,606
11,814
West Coast
www.laketahoeconcours.com
I believe you are referring to the DriveShaft and not the Jackshaft?
The 2005 is a Unique Drive Shaft that is NOT similar to others... and that is the only one you can use... BUT.... You can press on factory drivers from any "Dragon" model IQ as those have the same spline and the 2.86" pitch you want.
OR...Go with the Avid Drivers.
Ole Andre
55
5
8
05 shaft fits 13 pro but pro shaft dos not fit 05 900?
K
Jan 14, 2020
6
For the avid drivers does anyone know if it comes as a set of 2 or if I need to order 2? I tried contacting them with no luck.
K
Jan 14, 2020
6
Do you know if they come as a set on this website or do I need to order 2 of them?
