Injector removal
T
trestlecreek
Is there a video showing how to remove the injectors on a pro? Also does anyone know the name or website of the company that does injector cleaning?
The injectors need to be removed with the wiring harness connected. The connectors on the injector are glued on so don't try to disconnect them at the injectors. Follow the wiring harness away from the injectors and u will find a connector. You can disconnect it there. The 2 injectors will now be dangling from the wiring harness. Send the injectors and attached wiring to witchhunter.com.
$22 bucks each including new orings. Follow the website instructions for sending injectors.
Indy Specialty cleans and tests them for $25.00. Dan is a great guy to deal with.
No special tool needed. The injector assembly is held into the cylinder with two 6mm (10mm head) bolts. Remove the hood and air box and they are easy to remove.
