How many lbs of boost is this good for and at what elevation?
Sent from my SM-N976U using Tapatalk
Were you happy with how the clutching worked? How would it work with 3 or 5 lbs, if you have tried it?I was running 7lbs at 3-7k.
TURBO 3 CLUTCH KIT | Indy Specialty
(DESIGNED FOR 4000 FEET +)*IF YOU ARE RUNNING LOW ELEVATION TURBO, THE TURBO HEAVY WEIGHT IS A BETTER ALTERNATIVE.* Turbo3 Adjustable Clutch Weights What makes these better than other weights for turbo sleds? The unique design of the weights allow you to stay spooled while riding. High engagment...www.indyspecialty.com
Whose turbo if I may ask, and did you ever try the turbo kit's clutching first?It worked good I just put the sled back to stock. The person who bought the turbo kit didn't want all the clutching. I never ran it with 3-5 but would assume you could adjust the weights to work.
I sent my clutch to slp and had it shimmied and balanced. Best to install and check.They recommend reshimming the primary, did you have to reshim it?
