Anybody running Indy Dans turbo clutch package on there Axys?
How do you like it?
How do you like it?
What was goin on around the 9 second mark of the video?My experience with it is limited to low elevationcurrently I am running it at 600-1500ft right now with a silber at 3psi and have had good luck. Heading out west in a few weeks to try out in West Yellowstone.
Down low it pulls hard and has a smooth engagement when in the tight trees of the U.P.
Here is a link to a test run when a little while ago in some corn stubble with a dusting of snow...
https://www.youtube.com/watch?v=7sYmK05o2SI
Any other feed back on this kit. I ordered his weights and was supposed to get a 46-32/34 but instead got a mountain X helix. I assume that it is his turbo helix. Just didn't know how it runs and won't have time to return it and get the other helix I originally ordered.
I have the full setup now and will start testing soon. His helix angle is his secret but yes it is the same theory as say TRS clutch setup.
I can tell you Jon and Dan are awesome to work with.
We will be doing testing from sea level up to say 3500' and then maybe up to 6000' in April.
I have all 3 of his turbo weights and will test them but from the sounds of it we will like other the 1 or 3 weight.
I have done some talking with Bryan at B&M Fab which has been running this setup at the 6000' and loves it. Pulls like a freight train all the way through.
I am excited to test!
What belt are you going to run with Dan's set-up?
No.Did you have to reshim your spider?
