A
Hang with me. I live in Fairbanks, AK - it's cold here .
So last weekend I took my 2009 M8 SP out for MY my first real ride with the machine (bought it this fall - 1,000 miles). It ran great - for a while. It was about 25 below zero and part of the time I was breaking trail in about 18" of powder. Naturally some snow got through the vents and into the engine compartment. So I shut the machine off for about 30 minutes and when I re-started it gave code ECU 16 and ran ****ty. I headed for home and fricken ran out of gas at 71 miles on the tank! I was not riding it hard and I should have had ample gas to make it home until it threw the code and then it starting sucking the fuel. I rode it over 20 miles in limp mode. I had to walk 12 miles at 25 below zero to get back to my truck - not fun!
I figured it was something frozen since it ran fine and then sat for 30 minutes at 25 below zero and then ran ****ty. Anyway, I retrieved the machine (pulled it home) and then thawed it out in a garage. Apparently ECU 16 means something is wrong with the APV valves, cables, or servo motor. I checked the cable length and both were within specs. I put 5 gal of gas in the tank and it fired up - code gone.
I rode it again today. Same thing, let it sit at 20 below zero for a half hour and it throws the same code. I turned off the machine, open hood, turned the nut on the end of servo motor by hand, start up machine and code gone runs great again. It did that twice today, both times after sitting for 20 or 30 minutes at 20 below zero. Clearly the dang thing is freezing up at these temps and throwing the code. On a side note, today I also rode 71 miles and only burned 7.1 gallons. So apparently the servo motor or cables are freezing up?
Has anyone else experienced this? Any ideas on how to fix it? Yeah, I know, don't ride when it's 20 below zero! That's most of the winter up here.
Thanks for any ideas.
