M
Minndave13
I have a 2010 Dragon 800. I rebuilt the engine and everything was running good. I have 200 to 300 since rebuilding. I was out the other day and about two miles from home the sled developed a major engine bog. I limped it back home and have been working on it tonight. I happen to have another parts sled so I thought it might be the exhaust sensor, so I replaced the exhaust pipe (slp pipe, it already had a sensor in it and I didnt want to mess up the sensor by taking it out and they were both SLP pipes). I also drained some gas into a clear plastic bottle looking for water, I did not find any water. The sled still runs the same. I even tried replacing the computer and the coils. I also pulled one of the power valves and made sure it was not sticking. The sled will run above idle but nothing at idle and dies. I am almost thinking its bad gas but I get my gas (91 octane) from only one source and thats all the sled has only been run on. I should also note that I had a RK Tek head on the engine and I put a power commander 5 on the sled (running with what the commander came with). I put the original head back on, and took off the power commander, hoping it would have started running right again. Nope. I should also note that I tried swapping the Voltage Regulator with the other one I have (I do not know the condition of that voltage regulator but would assume it was good).
