When you turn the key on or pull the kill switch do you hear the fuel pump run for about 3 seconds? If not start there. I would check the wiring and connections from the kill switch. It has to be pluged in or the jumper plug has to be installed, you can t just unplug the kill switch on those sleds. You also need to check for spark. If you have the fuel pump running and you have spark, there are 2 relays on the back side of the computer box. one runs the injectors. I have seen those get corroded and stop working.
