I have a 2010 yz450f turbo, and since I had to ditch the left radiators to make space for the intake charge pipe, how does this sound for a cooling system setup:
Bypass circuit:engine‐> right radiator (with radiator blockers for on the go adjustment as needed/ finding the sweet spot)‐> pump‐> engine.
Open circuit: engine‐> right radiator‐> tunnel heat exchanger-> pump‐> engine.
Using a snowmobile heat exchanger, it should be plenty big enough for cooling needs. Will that setup give me enough coolant volume? Or should I add in a bottle?
