Hand warmer
B
Dec 3, 2011
7
I have a 2010 FX Nytro MTX. my right hand warmer quit working yesterday does anybody no where to start looking for a problem?
jrusher
498
285
Edmonton
Check to make sure wire connections on heater elements under grip are still connected, the soldered connections break pretty easy.. Use a meter to see if you have power there if not trace wires down from there..
Nov 28, 2010
167
9
18
Saskatchewan, Canada
unplug the hand warmer at the conection and see if there is continuity through the warmer itself. And as mentioned above check the wiring for broken wires. That would be the first step. No continuity means that there is a break in the element in the grip and it needs to be replaced.
