Grip n rip alighnment tool?
tinkerjohnson
1,134
242
Southern utah
Anybody have a alignment tool for rent? Or for sale I hate to buy one for a one time use but I wanna set my new sled up right out of the box. Are guys that are doing alignments seeing them off a long ways? are they off enough to worry about? Any input is appreciated, thanks
High Voltage
1,064
362
83
Helena, MT
Was wondering the same thing. How many of you have realigned your clutches? Seems to be the new todo, but is there really any benefit on the 2019-20s ? Seems like all the belt issues have gone away, or am I wrong?
tinkerjohnson
1,134
242
Southern utah
I think they are better yes, but setting it perfect or closer can't hurt anything. That's my thought anyways.
Devilmanak
4,261
1,534
Donnelly, ID
Talked to Big John the other day, he said that just installing the Grip N Rip poly bushing and adding one shim to distance the clutches will make a 50% improvement in belt life. I want the tool also, but spendy. Local shops in town (private) already said that they would be willing to borrow it, lol.
greeneman
557
188
Fairbanks Alaska
Just checked 2020 expert X 154 and alignment was just a bad as all the 18 and 19's I have done.
Jul 5, 2001
192
69
Have done over a dozen of them, 2018, 19, 20 and all out about the same + or - .030" from factory.......
front PTO = .150", Mag side = .085", drill stainless plate with 3/8" bit and push motor fwd against bolt and shim QRS .060" top shaft and you will be good ( all with in + or - .015" )
caper11
692
287
Northern alberta
Doesnt mean anything actually, If doo is using the same spec than of course GNR settings will make them be off.
Lots of newer sled with no belt problems, turbos etc and have never had an alignment.
tinkerjohnson
1,134
242
Southern utah
I just did my 2020 expert. Gnr torque stop 2 shims in the front pto and 2 in the mag side 5/16 hole in the mag plate and a 3mm shim in the qrs and that put me dead on the grip n rip specs
snowmanx
2,158
440
83
50
Polson, Montana
So are you really noticing a difference in belt life? Have you rode any of the sleds stock and then after aligning them? THanks
snowmanx
2,158
440
83
50
Polson, Montana
They are going to be off, as I'm sure ski doo has aligned the clutches with no load. With the grip n rip alignment, it aligns them as if the clutches were under load. The real question is, has it really made a difference?
greeneman
557
188
Fairbanks Alaska
Yes have done several that where getting under 300 miles a belt, since alignment getting way more.
greeneman
557
188
Fairbanks Alaska
Personal sled, 2018 850 154. Running same clutching for over 800 miles. It was working pretty good and rpm was always 7900 to 8000 in the area I ride. Did full alignment and first ride after sled what pulling 8400 rpm. Had to add weight to my ZRP ramps. I did not change anything except alignment. That was enough to convince me that I was wasting power riding it misaligned.
caper11
692
287
Northern alberta
Did you check your shift out after the alignment??
tinkerjohnson
1,134
242
Southern utah
I don't believe that the alignment alone will fix every problem with belt problems. Calibration is the #1 problem, possably venting is another. I no the 19s were a lot better due to venting and calibration changes from brp. But it's common sense to no that if your clutches are in good alignment under load the belt is gonna last longer, and clutching and performance are gonna be more on point all the time. Just the center to center changes .150 from off load to under load so its almost like a sacked out belt when new.
caper11
692
287
Northern alberta
Yes marked clutches with stripe and was shifting out same as it was before.
Your alignment must of been off alot, or something is amiss.
I personally know people who have used that tool, and between this forum and others i e talked to.
What you claim is a first. 4-500 rpm increase??? I take it you were not using the “max rpm” to gauge that difference???
Is the center to center is changing that much, belt deflection will be different.
greeneman
557
188
Fairbanks Alaska
You can believe whatever you want, don't align your clutch thats cool, has worked great for a lot of sled I have done that where eating belts. Have talked with Big John about some clutch and he nothing but good to say on the sleds he has aligned. You don't like don't do it.
