Anyone running one of these on 850 Axys ? I am wondering if there is room to mount a muff pot type cooker to the top inlet pipe of the can, and if it gets hot enough to heat your food ?
Thanks Wheel House .Have one on my sled, definately room on the elbo on the top to get a muffpot, that should cook pretty good up there as its jus the pipe.
Close to a 6 lb savings , no power loss or running issues at all , not sure about gains , going by seat of the pants feel, I think their might be . I have run GGB for the past several years on 4 other sleds and have never had any issues or power loss .Did you notice any difference in performance between the stock silencer and the GGB ? How much of a weight savings ?
Their is no problem with the rope with the Trail can or the quiet can, I can't speak for the Mountain can on the 850 but would guess that it might get hot enough .Make sure you remove your pull rope pulley if you install the GGB can, otherwise you will melt your pull cord rope in no time.
Guess I better check again , had not seen a problem the last time I checked , will look at it later today .It is a problem with the quiet can, two people I know have melted their pull cords by not removing the pulley. My last ride it just happened in fact.
