Full Throttle Bog
I have a 2022 Polaris Boost that has a terrible bog at only full throttle (not powder bog related). I brought it to the dealer and they said they fixed it by relearning the exhaust valves and updating to the 25 flash. I took it out afterwards and it still has this terrible bog at full throttle and also now idles high around 3200rpms. Any ideas what this could be?
Thinking fuel pump or injectors.
If your 2022 Polaris Boost still bogs at full throttle after exhaust valve relearn and a flash update, the issue could be fuel system, air intake leak, or TPS calibration. Is there any repair center near you?
I had the exhaust valves relearned and the newest flash put on it at the dealership. The sled still bogs and only tops out at 7300 rpms now. I am thinking it is injectors now or the reeds.
There is no air intake leak when I did a top down check using carb cleaner there was no variation in idle speeds.
