I'm about 15 lbs lighter than you. I can almost assure you will like your freeride in the softer settings. Especially in the front end.Will make it easier to ride.These things are stiff .At least my 20 and 21 are...I run mine almost all the way soft on compression setting in the front end for off trail.Cant remember where I ended up on rebound, but once I got it set, I left it alone. Left the springs pretty much in the factory setting.. These things are stiff, especially when new. Best is to play with adjustments, there's lots of them. If it not set up correctly they can be frustrating, but once set to your liking they are awesome.
