So is the c/c 17.5" on all M series from 07-11 on the front17.5" for the front on a M 07-11 the HCR will be 18.5"
As for the rear float I don't think the 07 had the float skid available till 08
K so even though they are an inch bigger. Can I still throw them on it and have no problems with ride quality or blowing one out? I would understand if you took an hcr and tried to put regular sno pro float on the front. It just would not fit the holes Cuz it's shorter. But if you just compress it in and bolt it up would it work??
It would probably work but would probably also create quite a bit more ski pressure.
Try setting them up with more sag equal to what you'd run with the stock length and dial in a bit more compression damping to compensate.
Me, I'd just get them shortened to the correct length though ..
How do you go about shortening them?
My buddy had an 07 m8 snopro all orange. Wouldn't I just have to change the rear shock? Isn't the skid all the same
