• I've received emails and PM's asking me about "Group Buys" and promotions.
    A Group Buy here on SnoWestOnline.com would be a situation where a normal member (non vendor or mfg) personally collects orders from other members. That member then uses those orders to negotiate a better price with the Vendor/Mfg for HIS/HER "Group" of buyers.
    Here is an example of a viable "Group Buy"
    http://www.snowestonline.com/forum/showthread.php?t=269222
    A promotion that has the words "Group Buy" in the title is still a promotion, and from the rules that were handed down to me by Harris Publications is that non-advertisers cannot run promotions or open sales programs on the forums outside of the swapmeet.
    If a members wants to become a group buy manager, maintain a thread and collect the funds and negotiate a group buy... as a member, you are welcome to do that as long as you are not attached to the business of the vendor or Mfg.
    If you are a vendor/MFG and you want to offer an EXCLUSIVE "SnoWestOnline ONLY" promotion that is exclusive to snowest readers, please contact me and you'll be able to put it up in the Polaris forums.
    Also, before any vendors/mfgs get all "riled up" over this know that the moderators are strictly volunteers and do not receive a dime from any advertising $$ spent on this site.
    As ALWAYS, since DAY ONE of me becoming a moderator, I have pioneered, supported and encouraged vendors and mfgs in getting the word out to our readers with "New Product Announcements.
    Have a great season.
    From this point on, all vendors/mfg's promoting Pre-Season tiered sales programs, in the Polaris Forums, that are not paid advertisers will be appropriately moved to the swapmeet section of the forums.
    MH
Four-stroke Pro's
Built 2 more naturally aspirated four-stoke Pro's this year and have a winter's worth of riding on all three. Have $2500 to $3000 into each of them since we all already had RX1 motors to donate. Reasonably simple swap. No machining, simple wire feed welding. Fortunately cheap clean Pro's with blown motors are easy to come by. We have them on 2016, 2014, and 2011 chassis's and they run head-to head with their 2-stroke brothers. My 2016 RMK 457# before, 469# after swap. Motors have anywhere from 5k to 14k miles on them but all run strong/identical. Next step is anti-ratchets: have to run tracks crazy tight. Fuel injected; improve running on steep downhill carves. Try a 163in Track. Very fun!
Here's riding in McCall last week. https://youtu.be/9y4tFI1D03Y
turbolover
Enduring the heat till Braap Season
3,670
2,380
So what motors are you putting in them? Pretty neat to see someone doing something different from the crowd.
About the only real drawback I can see on that is when you get stuck, you probably don't want to get that 4 stroke on its top.
I usually end up with my sled upside down to get it unstuck at least a couple of times every ride.
We typically roll our sleds out of stucks at least a couple times per ride. The RX1/apex motor has a dry sump so most of the oil sits in a reservoir. The little oil in the crankcase can run out the breather tube into the airbox when upside down. Only good thing about our carb versions is they shut off when they go upside down so we don't toast motors. We can roll out 3 or 4 times and not go low on oil. I have installed a solenoid valve on the breather before but feared it might malfunction and I don't want to build crankcase pressure. Been rolling them out for 15 years. A little oil out the belly pan once in a while is not a big deal.
Norway
1,931
443
83
45
Way cool. Congrats on some fine builds. They do sound awesome and if the weight penalty is only around 10-12lbs, kudos for a good quality build.
Sent fra min S60 via Tapatalk
jim
568
93
Boise
Turbo any of them? How is the handling compared to a stock Pro? I found the Apex to be very heavy front handling.
We've ridden lightened RX-1's 159's (less 80 lbs from stock) for years and have been able to make them go most anywhere. The yami motor in the pro chassis is another 60lbs lighter and massively more maneuverable. We are still learning what they can do. They're super easy to lay over, can hang a crazy steep sidehill and downhill carve like nothing we've ridden. The video has some sidehilling. Unfortunately none of have experience with stock pros. Our chassis's had blown motors. I guess our next step will be to let an experienced pro rider run them side by side.
TRS
Life Member
3,039
3,527
Cody, WY
I know an old boy that has that oil loss issue fixed. Send me a PM and I’ll give you his number.
Thanks for the tip. As far as Turbo's in any or them, not yet. There is plenty of room alongside the motor but I'm thinking the Apex fuel injected motor is a better candidate. We messed with MCX and Bender rear mounts on our RX1's but they added a lot of weight and we had to constantly fiddle with them. Another summer project will be seeing if we can get the Apex fuel injection rails to fit. Clearance between the motor and the steering link is pretty tight.
TRS
Life Member
3,039
3,527
Cody, WY
The gent I sent contact info on, can help you in the turbo dept also.
NHRoadking
510
203
What's the hp difference between the Poo 800 and the Yammy?
How is it that the difference in weight only came to 12 pounds?
sno*jet
2,050
612
very cool. love the sound, looks a lot more torque than a 2stroke. maybe could use a little bigger paddle but works great. I want!
SNWMBL
334
116
AK
The 3-cylinder FX Nytro motor is 112 lbs with flex joints but no oil or coolant. I believe the 4 cylinders are 12 lbs heavier. My guess is there are some other lightweight mods done to these sleds. Very cool though.
Killer Time Racing
894
163
Lower Michigan
Imo .... They sound and look WAY to high geared !!!
Sidehilling is done slow and with way less track speed than that .. with the torque those have you should be able to pull up to that hill like you guys are and at a stop hammer the throttle and bury it to the boards .. like instantly.
Most people change their clutching so it will not trench but it is done with less spring pressure to let it engage sooner ..
Cut them Grab handles off and turn the skis the wrong way along with your weight in a field and it will flip on it's side if you have your weight and throttle correct. Then find the spot you can balance your weight against the power to keep it in a big circle ... After that I'm betting your sidehilling will seem natural.
Then you will find you need to apply more throttle to keep the track spinning to maintain a good trench to settle into. As you continue along the hill foot placement is crucial. To far back you will go up hill and get stuck, to far forward it climbs out of the hole and goes down the hill ... So it's done a hundred ways but everyone does it at a slow pace or usally goes flying down the hill or give up and go up it !!!
Of course this is totally in my own opinion.. I'm from Michigan so I'm not a lifer !!
Into our second winter with 3 Polaris Pros w/4-stroke powerplants. Headed to Revelstoke on the 5th. Weighed my sled with 7 gallons, which is "ready to ride" for us. Gives us 70 miles which is twice a typical day for us. Our wet weight is a hair less than the 2019 Doo 850 154, wet weight of 551lbs. Frustrating the manufacturers don't produce a competitive 4-stroke when we can in our garage.
2019 Wet weights, Sidewinder 643lbs, Skidoo Summit sp 850 154, 551lbs, Pro 3in. 155 519lbs, Arctic Cat Alpha 154 at 540lbs.
