Fabcraft D&R kit?
W
wreckmaster
Has anyone installed one of these kits? It states that it fits 98-99 PS and 00-02 Mtn cats. I was looking for something for my '01 SnoPro that I'm going to build.
I was just wondering how the install went and the amount of clearance that you got?
thanks
wreckmaster
Is the front part of your Bulkhead/Tunnel notched out for the jackshaft? It looks fairly labor intensive but I think it will work really well for the direction I want to go on this build.
wreckmaster
we just got same dr kit from fabcraft call mike he will get you going in right direction ..... def some work involved
Modman is correct it's a Ton of work.... That aside I think you could fit a3" track. The bulkheads should be the same? I will post some pics as it comes along
i hear that if you just install 7 tooth drivers it will clear the tunnel. you may have to move the cooler but nothing this labour intensive.
avids or cr racing.but i also seen the fabcraft d+R aparently it works good but changing the drivers will allow you to run a newer track too.
i have a 02 thundercat i want to swap out the stock 151 and put in a 162/174..... iam subscribing to this thread
