Brake reservoir protector.
That’s because I sold them all the ones I have collected over the past 8 yearsthey all get linq brackets now from the factory..
Here's a review from Snowgoer:
Sure enough, when our mountain tester got some seat time – or, more appropriately for mountain applications, riding time standing above the small and narrow seat! – the machine was more playful in open areas. It was both easier to roll up and also holds its tilt angle with less effort.
He did experience a bit of a trade-off when tilting the sled on a slope and sidehilling, however. With the narrowness of the front end, there are circumstances where the sled will “panel out,” meaning the side panel of the sled will put enough force on the hill where it will unload the ski on which it’s supposed to be resting. The built-in adjustability should help with that – but it proved that riding at the narrowest, 34-inch settings may not be for everybody in all riding cicumstances.
That said, the new narrow Expert was also more playful in other situations as well. For instance, when climbing straight up a hill and then trying to whip the sled around for a re-entry or to square it up and go across the slope, it was much easier to make the sled change direction with the skis tucked a little more together. It was a bit of a handful on the rough, single-track trails that often lead to the playgrounds, however.
Decided to go with the Expert. Thanks folks. Gonna be a long summer!
WELCOME TO THE CLUB!Decided to go with the Expert. Thanks folks. Gonna be a long summer!
Apparently it handled so well that more and more of us are BUYING THEM!@!I thought this was supposed to be a response to how the 34" front handled!
My Size 12s have MORE than enough.
I also think they could NARROW those boards down just a bit.
1 Inch on the boards
2 inches on the side pannels
WHAT a difference that would make on Side-Hilling when your laying it over HARD.
So is the answer to make the boards a bit narrower and higher?What you guys are also missing is that those wide boards make the chassis "high center" way before it should when going through deep snow. With narrower boards the sled would cut the snow and drop deeper into the snow for more traction before getting stuck. This is so obvious when you simply clear under the boards and the sled walks out of the stuck.
The move to taller spindles on some brands has definitely helped get sleds through the snow. If the boards where also higher it could work but it must be a practical comfortable height. The narrow 34" stance on the 22 Doo may have more advantages than first thought. If the narrowed stance packs the snow more inline with the running boards they may not high center as bad.So is the answer to make the boards a bit narrower and higher?
Buddy of mine has a 165 Expert from last season and the turbo 165 Freeride this year.I originally had a Freeride 165 checked for next season but changed it to the Summit Expert ... Hopefully that was the right choice. I don't jump much or do big cornice drops. Do like to bash up hills pretending I'm a RMSHA racer from time to time, but I just hope the 34" isn't too narrow on steep sidehills
I like his Expert better as it feels much lighter and we tree ride anyway so the turbo doesn't get to stretch it's legs very often. I will say the Expert should have the rail braces from BRP added and the shocks on the Freeride are heavenly on the trail. I heard him say that the shocks might be as good of an upgrade as the turbo.
The 22 has the optional adjustment of 34" to 36" as I understand it.Yeah, but the 2020 Expert and the 2021 Freeride have the same 37" front end. The 2022 Experts have the 34" front end ... I'm sort of wondering if I'd prefer the 37" instead of the 34". I've ridden the 37" and did just fine with it, idk if I should have changed my sno check
