N
2013 800 rmk, exhaust valves not functioning and only 7k rpms. Plugged vent line from selenoid and got rpms back but have what I think is a lean bog at about 5300-5800 rpm with deceleration when running plugged. Selonoid seems to work when 12 volts is applied. Unplugged from harness and hooked volt meter up and started sled. Selenoid is getting 12 volts at idle and all thru the rpm range. Doesn’t seem to shut off voltage anywhere. Any other testing I can do? Don’t even know if this was a good test. Thank you
