Is this a new kit? Or the Evolution Air kit? I don't see anything on your website with Elevation kit in it.....Check out www.tomsshocks.com
It is our torsion bar delete kit. Uses airshocks for rear skid system. Comes with lockout for rear shock.
Still working on the IQS air kit
Can we see pictures of the kit instead of a cliff that someone is going to jump off of?This is our billet aluminum rear arm, and rocker kit, coupled with the Fox QSL rear air shock.
We use a billet rocker arm, 3 piece billet rear arm, different throttle rods, Fox Float 3 front track shock, and a Fox QSL R rear track shock.
If you are looking to make your sled more or less "floppy", you really need to start with the front ski shock springs. Let me answer your question with a question. If you remove 1 torsion spring (either side) is your sled more "floppy"? (Try a short ride with one spring disconnected. You will need to increase the remaining spring pressure.)Doesn't removing the torsion springs make the suspension more floppy, i.e., moves more side to side?
Yes. We simply take the play out of the rear heim joint with washers on either side.Do you guys have a way to lockout the t-motion with your setup?
No they do not wear out.
