Egt sensor, automotive replacement?
t30mg
843
404
Brush Prairie Wa
Is there an automotive EGT sensor that will work on the patriot 850 pipe?
Seems like I read somewhere about a duramax sensor but I can't find any info now..
t30mg
843
404
Brush Prairie Wa
Thanks for that.
That lead to this one which is the one I was thinking about.
Ordered 1 of each and will try them both to see if they work
IDspud
3,961
Oakley, ID
Same probe has a few different connectors over several years duramax engines.
Look up different engines/years and you’ll find the right connections.
S7even
62
22
8
29
Cascade Idaho
Perfect, I’ll check that out. Worst case is I’ll just have to butt connector them together, but even that is better than paying Polaris $200 for one.
spoon
Wrenching to ride is half the fun
1,230
636
Kootenays, BC
I also carry my home made resistor for temp sensor delete when it fails. Save a connector from failed sensor and put the correct resistor and no more codes. Runs good with hot pipe but can burble a bit with cold pipe. Good for saving a ride when it fails. Cant remember resistance offhand, 460 ohms I think, but not positive. If anyone cares I can check it tomorrow.
S7even
62
22
8
29
Cascade Idaho
@spoon could you check on what the exact resistance is supposed to be on that. I’m trying to chase down a running issue and I’m suspecting it might be the egt. It would be nice to just try the resistor and see what happens.
RMKillR
308
58
Wisco
Aren't the part number for the 850 and 2018 and newer 800 sensors the same?
