Easy sled lift
summ8rmk
Most handsome
12,368
6,039
yakima, wa.
link works from a windows computer.
i like the thought and ease but, if you try to use this method while stuck in the snow, you had better hope that the load applied to the tracks rod is less than the load retaining the sled.
Teth-Air
4,560
2,789
Calgary AB/Nelson BC
www.specified.ca
Throttle control lets you load it until your comfortable. You would not hit it hard and would be ready on the brake. It was very controllable.
03RMK800
173
Kremmling, Colorado
There was once a commercial device based on the same theory. Had a Y with hooks on the the two points and a length on the single center point. Even though it hooked at two points, it was the same cross rod, but the old tracks were steel and thicker rubber.. This was also before reverse was common, so you started with the hooks on top of the track, tied the free end to a tree or other anchor, and pulled yourself out. It would also work going forward according to literature, hooking to bottom of track.
Never owned one but gave serious thought to building my own. Never did. Bought a SkiDoo instead.;)
IDspud
3,959
Oakley, ID
I hear ya, going to ski doo would screw up the self powered option...?
