• I've received emails and PM's asking me about "Group Buys" and promotions.
    A Group Buy here on SnoWestOnline.com would be a situation where a normal member (non vendor or mfg) personally collects orders from other members. That member then uses those orders to negotiate a better price with the Vendor/Mfg for HIS/HER "Group" of buyers.
    Here is an example of a viable "Group Buy"
    http://www.snowestonline.com/forum/showthread.php?t=269222
    A promotion that has the words "Group Buy" in the title is still a promotion, and from the rules that were handed down to me by Harris Publications is that non-advertisers cannot run promotions or open sales programs on the forums outside of the swapmeet.
    If a members wants to become a group buy manager, maintain a thread and collect the funds and negotiate a group buy... as a member, you are welcome to do that as long as you are not attached to the business of the vendor or Mfg.
    If you are a vendor/MFG and you want to offer an EXCLUSIVE "SnoWestOnline ONLY" promotion that is exclusive to snowest readers, please contact me and you'll be able to put it up in the Polaris forums.
    Also, before any vendors/mfgs get all "riled up" over this know that the moderators are strictly volunteers and do not receive a dime from any advertising $$ spent on this site.
    As ALWAYS, since DAY ONE of me becoming a moderator, I have pioneered, supported and encouraged vendors and mfgs in getting the word out to our readers with "New Product Announcements.
    Have a great season.
    From this point on, all vendors/mfg's promoting Pre-Season tiered sales programs, in the Polaris Forums, that are not paid advertisers will be appropriately moved to the swapmeet section of the forums.
    MH
Drilling Rails for Scratchers
Feb 10, 2019
41
9
8
Saskatchewan
Am i a fool being that i am considering drilling my rails to install BRP spring scratchers?
Really want to use the BRP setup as i have a complete set almost brand new and a brand new set of springs to go with.
Cornfusion
93
69
18
Western Pa
Ive drilled a few to put on skidoo reversable scratchers and have had no I'll effects yet but we don't jump a ton
Sent from my SM-G960U using Tapatalk
sledhed
1,651
400
83
Lolo, Montana
I always look for a way around it... if you do drill make sure it is a spot that has lots of meat around it... these new rails are so lightened with material removed that I prefer to use an existing mounting hole if possible.
EDIT: That being said, I ended up going with the Ice Storm scratchers, they throw up a lot more than stock, I am impressed. I think I am going to finally put in the mtntk 3' cooler in my Axys that I bought a couple years ago for my Pro...
BeartoothBaron
699
621
93
Roberts, MT
Hmmm, I'd say it depends in part on how your ride. If you've bent rails before, then it's probably not worth the risk of weakening the rail. On the other hand it might not make enough difference to matter for you, even on a lighter rail. I've drilled new holes so I could run the front idler wheels and scratchers, and it didn't cause any problems, but that was on my old sled with heavier rails than an AXYS. I wouldn't say never, just that you're taking some risk: obviously, if you bend a rail, that's going to cost you more than a new pair of scratchers. If you do drill, try to keep it in a "meatier" area as mentioned, and I'd add to keep it away from the edges – I can't think of a better way to weaken a rail than a hole close to the edge of a highly stressed area.
Feb 10, 2019
41
9
8
Saskatchewan
Installed the ibexx 2.0
Didnt wanna drill anything new for the hangers, really bad spot to drill, IMO, so fabbed up some bolt on brackets
Ok so my other idea is what im going with after seeing your sliders.
im going to take a dremel and take out a little bit if the top of the slider. The BRP spring bracket will fit perfectly in between those two profiles on the rail. I will use a piece of aluminum flatbar on the backside of one of the cut outs in the rail. No holes needed.
will post pics when done
pepperhouse
80
44
18
you can also just tuck the end of the scratcher in the big hole in the rail .. it stays there nicely.. don't need any scratcher holders
This ☝️
Make the one hole a bit bigger and install that’s it done.
The BRP hangers just rip off anyway.
Teth-Air
3,568
1,624
Calgary AB/Nelson BC
www.specified.ca
I ride with a bunch of Doo's and their scratchers do a poor job of shooting snow as they are too thin to apply enough force, That said if you break off another type of scratcher it does nothing and then the Doo scratchers will look like a good option. Going this route really depends if you need a little or a lot of cooling.
