Curious if anyone has successfully installed the thinner Doo expert bars on an Axys?
I have been running them all winter without a mountain bar. They have a better bend and ergonomically feel better than the Polaris bar. I’ll give them five stars. They are thinner than the Polaris bar. Once you run them and you get back on a stock setup, it feels like the stock bars are a straight piece of pipe.
You will need a riser for an install.
You can buy the bars as an accessory with the cork, heat and grips installed. Natural aluminum is considerably cheaper than the red Expert bars. You re-pin the elements(just high heat) and they are plug and play.
Ski-Doo Deep Snow Small Diameter Handlebar for REV Gen4 860201974
Thank you. When you say re-pin - did you cut the plugs off and hard wire to the Polaris plug? Any guidance on wiring for an 850? All the brake and throttle blocks bolt up just fine with the thinner bar? Are the expert bars a two inch rise ?
I’m excited to try.
I’ll take a pic.
I slid the pins out of the stock connector and re-pined the Doo wires to utilize the stock connector.
I will build a riser, but used a 2.5” ROX riser with the stock block.
Every thing fits and works on the bars.
Thank you. Curious about the location of the pins in the plug to get the heaters working. Do I need a special tool to remove the pins? Also - I"m assuming any style of aftermarket riser should work on the bars? The bars look to be about 1" rise - that sound about right? So I'll look for a 6" rise to match the Polaris stock high bars. I'm ordering the bars now. Thank you for your help.It’s an 850. Pins are different. I can go back to the shop and take pics if you like.
I also reused the wire armor.
If you click on the pics they clear up.
Nice - so you needed to replace the connectors inside the plug as well? I have the RSI risers on my RMK - I think I can just get a longer pivoting risers and should be good to go.I have all the tools and connectors, so it’s pretty easy for me.
There is a ground wire and a hot wire. Doo uses a rheostat type controller for the hand warmers. You will only have HOT through the Polaris hand warmer switch no matter if you wire into hi or low.
I tried to install the Polaris hand warmers, they are to long and bunch up. You could use the old ‘90 short style and rewire them. I prefer the Doo style. They will get warm.
The connectors inside the plug, yes. The pins on the Doo hand warmers were the wrong ones.
Cool. I’m assuming Amazon could be a resource for the connectors. Worse case I could just use the old connectors and splice. Do you recall which location in the plug the doo heaters were installed?
Sounds good - I'm good with just having hi - run on that 90% of the time anyways. Old hands love the heat. . I have a 19 as well (850) - so I'm assuming I just need to identify the ground and the high? Or does it matter - and may only work when I have the switch on low or high depending on which connector I hit. Hope that makes sense. Super pumped to try the skinnier bars. I switched to a Munster Throttle and that allowed better grip and helped me a bunch - this will be nice. Any idea if the rise of the Doo bars is an inch? Trying to end up with around 7" total rise to match the Polaris high bars.Anytime I have had to replace a heated grip or thumb warmer it seems I can find a much better priced element or flipper that has the wrong connector. I always just cut and splice but do it where the protective webbed sleeve can slide over so you can't see the connection.
I just did one heated element and the thumb warmer on my 19 RMK and I used parts from a Proride as they where 1/3 the cost from my parts wholesaler rather than OEM.
I think TRS is implying that the Doo heater elements don't have high and low coils so you won't be able to go to low temp if you use them.
If you run both the high and low power wires from the sled to one side of the element and ground to the other, you will get high heat when your rocker is either up and down and off when in the middle. From memory I think you will find blue, blue with red stripe and brown wires. The brown will be ground. Double check my memory by ohming each wire to ground and the one with no resistance (short to ground) will be your ground wire.Sounds good - I'm good with just having hi - run on that 90% of the time anyways. Old hands love the heat. . I have a 19 as well (850) - so I'm assuming I just need to identify the ground and the high? Or does it matter - and may only work when I have the switch on low or high depending on which connector I hit. Hope that makes sense. Super pumped to try the skinnier bars. I switched to a Munster Throttle and that allowed better grip and helped me a bunch - this will be nice. Any idea if the rise of the Doo bars is an inch? Trying to end up with around 7" total rise to match the Polaris high bars.
