Digital Wrench fun facts
wfieldin
1,911
444
Denver
Found out some interesting riding information while getting the new flash installed in my Khaos. 850
I spend almost half of my time in the 5000 to 70000 rpm range.
Use the brake quite a bit, not sure why Polaris monitors this.
Zero Detonation events (SLP head, can and venting from day one)
No overheat events.
I knew that I am riding the 850 different than my previous 800's, RPM' definitely tells the story...... I feel this sled stays on top of the snow at lower rpm's with more braking.
TRS Clutching......Pro Grears.
BG567
11
9
Whitecourt, Alberta
I grabbed a screenshot while getting my new reflash installed as well. Always fun to see the numbers. Mechanic said he had not seen very many sleds with as much WOT as mine.
Sled is a 2019 850 163 2.6 with pro gears and SLP can, and stock clutching. Runs about 8150 to 8250 at 5k to 7k elevation. Just rolled over 2000kms.
BG567
11
9
Whitecourt, Alberta
So to be clear, which flash are you getting and which ones have you guys tried already?
I have had every flash available. The 2019.5 and this current flash from 2 weeks ago being the best. 2019 flash was way to rich, and the 2020 flash started randomly eating plugs. it would also leave black plumes in the snow with every WOT event.
Teth-Air
4,557
2,783
Calgary AB/Nelson BC
www.specified.ca
Thanks, that is what I thought only my dealer was not aware of it. My early 2020 flash has been running really well only it does leave those black streaks and it was still kinda fat on the bottom end until I went to hotter spark plugs.
Please give us feedback on how it runs.
Mentzel
359
212
its the VES extreme crude oil..
wfieldin
1,911
444
Denver
must not be much open area.
Correct.... not much open areas,
maybe some Significant trail to access the goods?
very little trail riding to the goods
