Digatron EGT probes coming loose
W
Wood
Has anyone had this problem? I lost one motor because of this.....bought new compression sleeves/nuts, used high temp retaining compound and checked them after only a short time and same problem. What is the deal??? Anyone?
The problem sounds like you are not using weld in bungs. The clamp on bungs are NOT the way to go. Get the bungs welded on, and your problems will go away.
What's the diff? It's not the clamp that's coming loose...it's the compression nut/probe.
Clamp on ones must get to vibrating or something, we have had the same problem. Weld on fittings cured our problems too.
Heres what I think happens; the nut is about 1/2 inch wide and your wrench is narrower so after they have been tightened a few times the nut gets mushroomed and wont clamp against the ferule. Ive had this problem many times over the years so I keep extra nuts and ferules in the tool box. You can get them at Ace Hardware pretty cheap. I agree the weld ins are better, they are typically a little taller and steel instead of brass
also note that you get intense sound wave vibrations plus the high heat intensity in different locations through the exhaust...in a very very rare cases you have to move to a new location. VERY RARE
Just get weld on bungs and do it right...in almost every single occasion that will fix your problem.
I have clamp on style egt sensors and need to convert to weld on style. Does the clamp and stud on the clamp style sensor screw off so I can use the same sensors? Do you grab onto the square piece on the sensor and back off the sensor?
on the southland and egt probes the cap is universal..just weld on the bung and screw down just as you did with clamp ons.
When you remove your probes the ferel is pressed in place (normally) and holds to your egt sensor...the cap moves freely above. You have to buy the weld on fitting you cant just peel the base off of your clamp ons.
guys with coated pipes..sharpy draw a circle around a nickle with your intended PROBE PLACEMENT hole in the center...grind off the coating just to the circle...weld will run perfectly to the edge of the coating. Nice install
Where do you ground with the nickel method?
Clean a spot on the inside of the pipe or will the ground go through the coating?
