D&D 720 big bore for ZR/ZL/Powder
F
firecat99
Like the title says!!
720 D&D kit based off the 98/99 carbed bottomend, Comes with PSI pipes, Delta force Reeds, All electronics for a drop in and go motor. Only has 600kms from ground up build, Looking to get $1500, this thing is a rocket for what it is just plug your main wiring harness in and let her rip its a true 2 pull -30 motor.
what neddle, tube, and jets are you using and altitude if you dont mind me asking. Thanks
Iam using F5 carbs all stock F5 set up just upped my jets to 440 at 0-2000 and it flat out rips and when the temp drops to about -25C she really wakes up.
is this based on the 700 bottom end? cause if it is i would be very interested
Based off the 5/600 bottomend, there an easyer and cheaper motor to build, also I can run down clutched out F7s with this motor.
