Couple G4 tidbits from haydays
madmax
Artic Cat Polaris Ski-Doo Klim
Interesting toe hold concept! :)
The limiter strap adjuster might be a bugger to use when packed with ice and snow though. Nice idea for sure!
the limiter strap adjuster is pimp imo! would look better in billet al. tho. wonder what holds it put, probably gotta loosen/tighten the center bolt?
aftermarket is gonna snatch this one up and have a push button on the bars for it soon i bet. skinz did the rear coupling, but if you could just suck the front down quickly or let it out, that would be just as good if not better.
That limiter strap adjuster is not new this year. May be first production sled though?
Just like the floppy rear rails that nobody knows about, been out for 2 years now.
GS6
GS6
Exactly, old tech moved to the G4. BRP has the patents wrapped up, too, so someone will have to twist the IP to offer new versions.
It was and still is an accessory to add, the sled in the booth under the tent was there to show off some of the accessories for the G4. Cheers dave
I had the limter strap on my Freeride 154" 2016 last year.
It was ok quality, no problem.
But on that machine it was useless, it was nose heavy anyway....
G4 felt so much better in that respect, main reason why i will have that for this year.
Will see if I need it on the G4, first service thing if so.
The adjustable raiser is a must, would like a picture, way too high on the prototypes at least.
You can adjust the adjustable limiter strap to where ever you want it. And the G4 sleds will have a riser that is 1 inch shorter than the prototypes, we don't change them during the prototype sessions because they are already expensive to build, so changes are noted before, during or after prototype sessions with riders and then changed in the production run. The adjustable riser is great but once you know your size it is lighter and easy just to get the specific riser for your height. cheers dave
starter
I assume that the starter bendix does not come installed when the unit is ordered without an electric start? If not, can the starter bendix be installed without removing the motor and simply pulling the mag cover?
Toe hold on an off-trail machine? :face-icon-small-con
Is that starter nosed into the recoil, or is that a separate pc?
Either way - it appears to be a new recoil housing.
Actually appears to be a whole new recoil design altogether. (actuation)
I wonder if it's plastic or alum?
Yes bendix does not come installed, but if you buy a kit you can install it after, without taking out the engine.
