Cooker / Food Heater?
G-Force
863
189
Kamloops BC
Have a feeling I (sadly) know the answer but.. Anyone know of a setup for a Hotdogger / cooker of some sort for a snowbike? Sooo nice having hot food on the trail with the sled, kind of gotten used to it haha.
Looked at the header on my '18 450 SX-F, doesn't seem to be much in the way of real estate. I would think that the muffler area would see a lot of residual snow, and negate the heat provided?
jrlastofthebreed
It seemed like a good idea at the time
112
30
Coeur d'Alene ID
i do burritos and sandwiches in aluminum foil inside my engine blanket and on top of my crank case. They stay fairly dry and after about an hour of riding my foods warm!
Jan 8, 2017
83
16
8
Firebox Nano twig stove. Collapses to flat nothing, lightweight and burns hot with twigs and branches. Also serves as an emergency cook stove and snowmelter with Esbit solid fuel pellets.
I spent lots of time and was determined to make one work but so far have not gotten anything to be hot enough. I started by building a bracket that holds the hot pot next to the cylinder. After 4 hours of riding, my food was barely warm. There's just no room in there to mount it to the pipe. I still haven't given up yet. I just need a revelation on what to try next.
Cooksend
319
116
I started carrying a small MSR cooker and a tin cup. Great for daily soups or a smart item in a survival situation. Works great! You can also cook soups right in the can.
Jan 8, 2017
83
16
8
How does it work for winter use? I decided against one as I was told the fuel canisters don’t work so well in cold weather.
Cooksend
319
116
Never an issue. I originally got it for summer pck trips and started to bring it along on the sled and snowbike. Good fuel for riding when you can eat a sandwich and can of Progresso soup mid day! I will also bring Mountain House Food with and boil water to prepare the food. That works great when you want to split food with someone!
G-Force
863
189
Kamloops BC
Some good options. Might have to look into a little stove type setup.
Was just hoping to keep more stuff from the tunnel bag and such is all.
Jun 23, 2004
1,928
533
Black Diamond, WA
There was a guy on here making a high temp cover for a hotdogger but I don't think it ever worked
I mounted a cooker on my YZ 450, had a good spot on the pipe with enough room and that pipe is freaking hot, but snow kicked up sucked all the heat out of it Built a shield to keep snow from flinging up from the track, still cold food.
Gave up on the idea
