It seems if you just snug the cap it doesn't leak....ovetightening distorts the reservoir threaded area and then they leak. Someone makes a aluminum insert that goes in the reservoir inlet that holds it true and supposedly stops the leaks. It is on this page...http://www.dootalk.com/dtproducts.php
My fuel gauge quit working on my 08 800 XP. It reads empty all the time. I have checked the fuse and connections. Any ideas? Really don't want to take it to the dealer.
My '08 leaks once in awhile also, as you have seen it is almost impossible to get at. I don't think there is alot a guy can do unless you want to start pulling your sled apart.
I have been riding ski doo's for eleven years and now I have an 08 xp 146'' the only way to fix these sleds is to find the biggest tree in the forest and hit it head on.
Common... lots of factory box mods u can do, SLP makes powder valves for top of box, that's what I started with, also have an extra air intakes vent kit, lots of guys mod the intake box at the back, right infront of fuel tank, cutting big holes and add pre filter material to cover holes and that seems to work good. That will be my choice if powder valves don't work, or I will cut more hole in top of front airbox next to powder valves and cover with material... hope it helps!anyone else have problems with the air filter clogging in mid to deep snow? my sled runs like **** when that filter is clogged, but just one swipe over it and it runs awesome! any solutions or suggestions?
I am on my third set of rear suspenion drop brackets anyone have a solution. Maybe I'm just a fatf**k that needs to take it easy ??
I had a 09 summit 600etec throttle stick off it went with out me done finished!
Less then 400m ,everybody that had this happen report it so we can get something done about it.
I have an 09 600etec, and so far its fine, 130 miles. Do you know what caused this.
